Hi, first post.
CBR400RR NC29, 1990 plate
Just had a recent issue. As the title says, when I put the bike into gear, it dies. This is clearly an electrical issue as the bike starts and revs quite nicely. The sidestand light works, however I notice from the wiring diagram for the bike that a wire leads off to the ignition control unit as well.
I had to leave the bike and get the car into work so I'm getting a bit of feedback before I check it over tonight.
My question, other than simply checking the side stand switch (and the clutch switch), are there any usual suspects I should also be checking if the sidstand switch and clutch are OK. Is this a common prob?
Many thanks in advance.
