hi lads , would blackbird front brake discs fit a 900 rrx? my wheel is 16". discs are warped on bike, just looking at options, thanks
Different offset, but the wheel hubs may be different widths. You need to find out the width across the discs on both wheels. If the wheel hubs are the same width then you would need to space either the discs or the calipers to make up the difference in offset. Or swap the disc rotors onto your 900RR carriers.
900RRX should be 62mm bore, 78mm PCD and 21mm offset.
Late 'Bird should be 62mm bore, 78mm PCD and 18.5mm offset.
Early 'Bird should be 58mm bore, 74mm PCD and 22mm offset.
Metal Gear
