I am trying to bleed the clutch but am not getting any results.
NOW i made a major $#%# ,
If you look at the attached pic.
When i removed the slave cylinder the workshop manual said to add some silicone grease to the indicated area on the pic.
I added silicone sealant there could this be why the clutch lever is not pumping up ?
My problem is the brake fluid is flowing from MC to SC just fine when bleeding but the clutch does not pump up.
Second is the indicated area the baja bolt for the MC ?
