1 - 2 of 2 Posts
Hi guys I'm still battling away getting my 05 blade gearbox repaired but I've have made a big mistake while Removing the blind bearing in the gearbox I didnt read the manual properly and went ahead and removed it only to find out its pinned and you are supposed to spilit the cases I think the pin was quite soft as it did come out quite easily and did no damage to the housing in the cases.one of the engineers I work with had a look and said just install the new bearing with bearing lock and not to worry.whats your thoughts on this please if I need to replace the top case then it's going to be broken up for spares as I've now run out of funds
Thanks
1 - 2 of 2 Posts
