1 - 2 of 2 Posts
I Have A 02 954rr and I was wanting to give it a clean look on the sides and fiber glass the holes shut were the blinkers are then put the blinkers in the hole in the upper corner of the head light...I was just wondering Has anyone done this mod and if so how hard was it?? and what did you need?:huh:
Check this thread: http://www.fireblades.org/forums/honda-fireblade/7444-did-hondagal-signal-mod-cool.html
The original write-up I did is long gone. Also search "brow lights" and "hondagal signal mod". For more info. I didn't invent it, btw. I learned about it on here.
However, I did the brow lights as turn signals in addition to the side lights. I'd consider leaving them there for better visibility. You can get ones that are flush and eliminate the large stock stalk ones.
1 - 2 of 2 Posts
