1 - 20 of 22 Posts
i have more problems,, ok i blow (light white smoke) when i rev the bike in neutral, i did look and my coolent was empty in the res.added some and some mixed with h20, still blowing smoke.any ideas plz
This is with the engine warmed up after a ride?
The reservoir doesn't matter.
Is the radiator full?
didnt get to check the radiator, got dark, but i filled the res, a while ago and now its empty, i start it for a min or two let it idle and rev it and smoke on the revs,,, also my #2 carb spits back? i live in florida never cold
It's not unusual to see some white smoke from a cold engine.
Are the header pipes all similar temperatures?
Has the bike been sitting for a while?
Have you changed anything before the carb started playing up?
bike sat for two weeks dead batt, bought a new one(old one said had a weak charge hold) headers are full yoshi exhaust, i had a hesitation when would rev, put on new carbs that i got free and one spits and white smoke, but no hesitation
Why did you replace the carbs?
to see if the carbs where giving me the hesitation, if i need to sync them or clean them, i used seafoam and got i results, so i swapped
I would think you would need to jet them to suit the exhaust system.
soeey another question the tree wire coming and going to the stator done need to connect in any order or will it mess ug the charging phases
Nope. All three phases are the same so it doesn't matter.
i wouldnt think that it wouold that big of an effect but i'll look into that. my bad on the typing
If you mean putting a full exhaust system on won't have much effect, it's just the opposite and would certainly benefit from rejetting.
so is white smoke oil or coolent?
Coolant generally but oil being burned without flame tends to be white.
Sounds like it's just condensation though.
well i had the exhaust on for a while a have had no problems untill now
The hesitation just started recently?
It was fine before?
Have you replaced the air filter and spark plugs recently?
Discussion Starter #17
plugs where brand new, filter was not(used)only problem i had before was charging system which is all new and it hesitated a bit but th r/r was bad and didnt give the right power at the right time of rpm, once i replaced that i was good until it sat for two weeks and then dead batt, hesitation and smoke,, it did get rained on but had a semiwater rest. cover
Have you checked for water in the tank?
Discussion Starter #19
right now i have a bottle set up as a temp tank 32oz bottle drilled hole and the line is enserted and duct taped for air tight(all gas) but the hesitation is gone with the new carbs that the #2 spits, if i put my hand over the v-stack it does nothing on the other 3 it will start to air starve the motor and you can hear the diff
Carbs sound like they need to be sinked, If the tank is air tight it will cause a lean condition. It needs to be vented, The stock tank is vented
1 - 20 of 22 Posts
