Going from 100mm to 103mm bore your increase is about 6.1% or 1060cc
How are you planning on doing this? Have you located a replating service accessible to you?
Now if you were to have a stroke that was 3mm longer you would need a 1.5mm shorter rod to keep deck height the same. This increases your piston speed and you may lose some top end rpm (which is where extra hp would be gained).
HRC had a kit for this motor, it may still be available, why not go that proven and tested direction? On the other hand why not go for a 1098/1198 for the same money of your completed project?
