1 - 20 of 25 Posts
Looking for some advice on proper tie down technique and suggestions as to what equipment should be used.
What tie downs should I go with? Ancra Red Snappers or The Original tie downs? And what about soft hook extensions 12 or 18”?
What’s the best spot on a sport bike to tie down from, the lower triple?
Wheel tie down strap on the back tire enough to hold the bike from moving around?
Any other help would be appreciated.
I use the Ancra originals. I haven't seen the red snappers. Are they rated for less or more pounds? If less, go with the Ancra Originals. Since the trailer you have looks like it has tie down points front and rear, your best bet is around the triple, as you suggested. I'd recommend the Ancra 18" soft ties, as the 12" will barely give enough length to go around the triple. In the back, I'd run softies through the passenger pegs, or somewhere in that area, one on each side, to hold the rear down. Don't tighten them too much, as you'll end up pulling the front wheel away from the chock. The idea is to just prevent the back from hopping around. Ideally, you'd want to pull both the front and rear straps forward, but that may not be possible depending on where tie-down hooks are on your trailer. Pulling the rear ones rearward will work as long as they aren't pulled too tight.
Ancras only.... Ask Bubba what happens when you use others.... As far as where to hook, I hooked soft ties to the rear pegs as HG2 said, but the front I ran throught he motor mounts where the sliders go on the sides, and run them foward and out. This allows you to compress the forks a bit without putting any torsion on them. I hauled mine many miles like this without it budging a bit.
Chris
As always, you're a wealth of information!! :thumb:
See the link below for info on the Red Snappers,
http://cyborgcycles.com/trnsprt.html
He has the worst website I've ever seen (an e-mail and phone number only!) but I've been using D-Straps for about a year now. They use carbiners instead of hooks and have the soft strap built into the end. They hold as well as ancras, and seem to age just as well too.
Thanks, I've been towing bikes around for about 10 years and have picked up a few tricks here and there. Those red snappers must be something fairly new? I've seen other brands with another hook on the end. I've never felt like I needed them. In my trailer I ran etrack so I can put my tie down rings in the floor anywhere I'd like, so a friend showed me a great tiedown method that only uses 2 straps, one on each side of the bike, in the rearset area. I loop a soft tie through the subframe, just above the rearsets, then pull the strap forward about 45 degrees. Must have a wheel chock. Two straps and it's solid. Compresses the front and rear at the same time. Don't think you can do that with your trailer, though. Of course, if one strap breaks, I'm screwed. I check all straps and soft ties after each tow. If any have a hint of fraying, they go in the garbage. I always carry extra soft ties and tie down straps...just ask bubba! :D
soon2b954 said:
Ancra recommends the Red Snapper as per this package scan from Newenough.com
http://www.newenough.com/product_pictures/a/ancra_original_tiedown/ancra_originals_application.jpg
I'll have to check them out when I need replacements. But, does that listing mean Ancra red or black red snappers, or does it mean you can choose between red or black originals, or red snappers? Not totally clear, except for smaller bikes they recommend red or black, or brites. :huh: Anyway, I've used the originals with no problems! Happy tie down shopping! :thumb:
You can always drill a hole in the side of the rails to make new tie down points for the hook to go through. As stated, have all straps pull forward. If you don't have pass. pegs, there is a crossbar near the battert try you can hook to.
We use them to bring in crashed bikes on the trailer. I have seen (and failed at tech) many bikes that had a Canyon Dancer used and the grips mashed so bad the throttle sticks wide open. Then again, people use them with no ill effects. Personally I use soft straps on the lower triple clamp.
Thanks Bob.
I've seen people completely compress their front suspension with these things, and I would assume these are the people who wreck their grips.
I've got a couple of Ancras modded with 'biners that work great for all sorts of tie-down chores... :thumb:
Just cut the stock hooks off with a bolt cutter and replace them with decent carabiners...works perfect... :nod:
Identical to Ancra's original except with an industrial quality snap hook and spring loaded keeper AT ONE END to provide an extra measure of security.
Why would you want an "extra measure of security" on just one end? :huh:
That type of cargo tie is used to make a "sub-assembly" with a D-Ring attachment....that way they don't get separated while reconfiguring the trailer.
Then shouldn't the ad read as such, instead of touting added security?
For different configurations of freight, all straps are not necessarily in use...
But if they are clipped into the D-Rings, the strap itself does not fall off and become fouled, lost, or a road hazard....ie it's "secured"...
Aw hell, JUST GO FUCK YOURSELF!!!
Did you mean.... AHJGFY-ROTFLMAO?!??!?!
1 - 20 of 25 Posts
