hey everyone, i recently purchased these arashi rotors about a month ago. i did not use new pads because the ones i had still had plenty of life left and new ones cost over $100 here. i just sanded them to freshen them up and put them back on. when i first used the brakes and parked the bike i realized the pads were only making contact on the both edges of the rotor (front right was warped), it made a dark gray line and the middle part of the rotor was untouched, gradually more and more contact was being made when the pads were bedding in and becoming flat. when I look at the rotor now i can see that the edge is dark gray possibly from over heating because heat was not dispersed throughout the whole rotor surface? :idunno: the front left one looks normal i guess because the rotor was not warped and the pad was worn flat from the beginning. I don't think that this is bluing, i just think that the pad was rubbing harder in that area because it was not flat from the old warped rotor. I don't notice any shuddering or pulsing, does the pic look normal to you guys? sorry for the long story, i'm just really get worried about small things :rotfl:
hey everyone, i recently purchased these arashi rotors about a month ago. i did not use new pads because the ones i had still had plenty of life left and new ones cost over $100 here. i just sanded them to freshen them up and put them back on. when i first used the brakes and parked the bike i realized the pads were only making contact on the both edges of the rotor (front right was warped), it made a dark gray line and the middle part of the rotor was untouched, gradually more and more contact was being made when the pads were bedding in and becoming flat (previous rotors were warped). when I look at the rotor now i can see that the edge is dark gray possibly from over heating because heat was not dispersed throughout the whole rotor surface? :idunno: the front left one looks normal i guess because the rotor was not warped and the pad was worn flat from the beginning. I don't think that this is bluing, i just think that the pad war rubbing harder in that area because it was not flat from the old warped rotor. I don't notice any shuddering or pulsing, does the pic look normal to you guys? sorry for the long story, i'm just really get worried about small things :rotfl:
Doesn't look like they're getting too hot.
Does the wheel spin okay when the discs are hot?
Did you clean the pistons before pushing them into the calipers?
well when they are cold i can give it a hard push and will will go about one or one and a half turns no problem. after breaking hard when i touch them they don't seem to be very hot but i didn't try spinning them when hot. it is easy to coast the bike after having a ride, the brakes don't seem to be grabbing. yes, i cleaned the pistons and gave them a nice scrub with a toothbrush :D does that dark gray part on the outer edge seem normal to you?
Ok, thanks for the help. Btw, sorry if this is not the right place for this but i have a highmount exhaust and where the pipe goes from 2-1 the pipe leaks a little and causes a rattle sound when taking off in first gear. Any way i can resolve this?
Welding it. Or thats what i did whit my Devil highmount. You probably allready cut the midpipe so it's useless whit any other muffler.
edit. OOPS! Didn't look how old the thread was.
