I'm looking to buy a set of Galfer wave front rotors for an '00 RC51 and possibly an '04 600RR - one of the sites I looked at listed a set that fit the 600RR, 1000RR, RC51, CBR600...
Do all these bikes really take the same front brake rotor? I called them to find out but there's no answer.
I'm particularly interested to know if rotors off the '04 600RR will fit on the '00 RC51 - instead of buying new ones I could just do a swap off my buddys rashed bike...
Thanks,
-Mike
I would avoid someone saying that. I know :down: that rotors off a 1000RR will NOT fit an RC51 (larger diameter on the 1000RR)
Thanks for the help guys -
After some research I found out that the RC51 and 1000RR use 320mm rotors and the 600RR uses 310mm rotors. The swap isn't gonna work.
-Mike
you can always acquire the 5mm spacers and longer bolts (10x1.25x67mm)to utilize the 320mm rotor disks on the 04/06 1000RR.......that's what I'm doing...
