I am considering building a trailer, and figured the more input the better. It will be 8' wide x 12' or 14', single axle with fold down door and curbside walk door. I need enough space for 2 or 3 bikes and all the gear. I would like to build a couple fold down bunks, so I can sleep in it. The things I'm not sure about are, v nose or square? Should I wire it for 110 or 12 volts? Buy an ezup or put a roll up awning on the trailer? Toolboxes or built in cabinets? D rings or track on the floor? Any tips or suggestions for setup would be great. Thanks
As someone that is looking I was told that one foot of width is like two of length on towing. You might consider a 7x16 rather than a 8x12 :idunno:
Also you might consider a 12 volt system with an inverter from 110. That way if you have 110 available you can save batteries and maybe run higher load items like AC, heat or a compressor other wise you lighting still works.
If your going to build it that big, put double axls on it, one with electric brakes. ITs going to be too heavy for one, even a 5k. And it will tow a whole lot better.
Absolutely! They won't sell anything larger than a 6x12 without dual axles and brakes, so you probably should build one without those 2 things. When I bought my 7x14, brakes were required, and there weren't any with single axles.
Thanks for the input guys. You are probably right about the using tandem axles instead of a single. I just hate the thought of using 14 or 15 inch wheels. I have an 8k axle with 16 inch wheels laying around that I was going to use, but I may have to reconsider.
Vendor
I would think unless you have most of the stuff to build it already, it would be cheaper to buy a used 7X14 and then put the stuff in it you want. I carry 2 bikes/generator/gear/big cooler, easily in my 6X12. I'm putting a tool cabinet on the floor in front of the right bike with a cabinet above it. We have carried 3 bikes in our 7X14 and all gear, and that wasnt a problem either. Our 7X14 has dual axle and electric brakes.
I do have most of the material and all the tools to build it. My primary reason for building my own is quality. I haven't really found any trailers that are built the way I would. I am sure I can find one cheaper than I can build, but so far I am not very impressed by the quality.
