The bike I'm looking at needs some work it needs one of the fairings replaced a turn signal and a mirror a I think he said something about the brakes to the bike has 25xxx miles on it he wants 3500 for I think that's to high for the work that needs done what do you guys think
Seems high to me if it needs work, but without knowing exactly what needs doing it's impossible to say.
What's wrong with the brakes?
I agree. $3500. is about average for a 01 929 in good shape. By the time you do repairs to bring it to "good shape", you're probably going to be into it for a lot more than $3500. Itemize repairs and low ball him....
Mileage????
I Dont mind doing the work on it but want a fair price for the condition I was thinking more like 2500-2800 and I'll ask him about the brakes when I go to work today I work with the guy that's selling
That's about what I paid for mine and a few months after, I know that 2700 would have done the deal, still love the bike though, but I regret the price.
Mine is MINT but it needed work to bring it up to speed. Here is what you will probably need. but of course if the guy has maintence records you may be able to skip some of it.
oil/filter - cheap insurance and you probably have no idea when it was done last
Brakes on the front - not real expensive might i suggest EBC HH mine needed them at 21k first brake job it ever had besides fluid flushes
Brake fluid change - not expensive but you might as well but on some braided lines when you do that. lines run you about 150 for a complete set
Air filter - cheap and easy go with stock. around 30 bucks
tires - see how old they are and what they look like mine were almost new
chain/sprocket - mine looks perfect all original but my dad rode it VERY easy
plugs - 5.49 each going to do that when i have the valves checked
valve check - can be pricey if you dont use an independent mechanic like im going to do
rear shock - mine was TOAST! 800 dollar elka custom shock solved this and I put it on myself
fork fluid change at the very least - seems not many people if any do this. i will be having mine done with a race tech spring and rebuild kit to match my riding style and weight. but you should at least dump the oil and put some synthetic in there.
battery - mine was replaced at 21k. just fyi
cosmetically mine was mint but i did replace the grips which were getting worn out. best 20 bucks i probably spent.
when i changed the factory exhaust... the header bolts were basically finger tight. so with that amount of miles you probably want to check a few bolts here and there.
any other advice you need just let us know. as you can see the bill for bringing the bike back up to safe and reliable standards can run you some coin. i cant tell you if that price is worth it or not. thats something you need to decide but i can at least tell ya what you looking at needing with the year and miles on the bike. everything else on my bike seems great. no clutch issues or engine noises from the cam chain currently. but like i said... i knew who owned it and i knew how it was ridden. barely ever red lined and never wheelied except for small power wheelies when too much throttle was used. but never wheelied intentionally.
