1 - 19 of 19 Posts
Ok I've search and found a couple different post on how to bypass the key switch on different CBR's and I've tryed them but nothing works on my 929, the diode thing but everytime I ture on the stop/start switch it blows fuses,
Which fuses are blowing?
30 amp on starter relay
just the 30 at the starter relay, everything wired back to stock
no everything works fine stock it's when I tryed to bypass the key switch it blows fuse
I've put the motor in a quad and want to get rid of anything not needed
Don't take this personally, but I don't know if your trying to bypass the key on a stolen bike or not.
This same thought came to me in another thread I was trying to help a guy and I started insisting on him calling a locksmith.
Just use the key because I can't help you.
go to this web page ( Hardtimes Custom Quads - Home ) this is what I do, I build quads for other people, nothing stolen, this is my first Honda so I need a little help with the wiring
Discussion Starter #14
USA
Ok, lets take this to PMs. I don't want a searchable solution on the forum. It would be far too easy for someone to steal a bike with this info and although another member discusses what to replace in the ignition switch to repair a broken ignition switch, there is a component missing to make it work without the ignition switch.
Discussion Starter #16
ok
thanks
Discussion Starter #17
unfetteredmight thanks again for all the help could not have done it without your help
Michael
Trying to reach unfetteredmight. please help. I recently repossessed my 900 from a guy that should be strapped in a stock honda odyssey and pushed over a cliff. I'm slowly stitching my bike back together but before I go too far I need to get it started. I have a spare key I kept, unfortunately the ignition switch is gone. I've done some research but nothing helpfull. "Diodes that activate fuel pumps"......??? I'm not a wizard but I know my bike and there is NO fuel pump. 12v down to 9v...?? WHAT??? Can someone just give me a straight real answer.?
1 - 19 of 19 Posts
