1 - 15 of 15 Posts
If I take the cam chain tensioner thats on the right side of the motor out, will I have to adjust it when I put it back in the motor? The motor is out of the bike and im taking it in to get a motor mount fixed. The broken mount is located directly below the CCT. Im afriad the gasket on the CCT will melt from the heat from welding and ****. Should I have any worries about removing the CCT? Thanks
02 CBR 954
Discussion Starter #2 (Edited)
As you can see from this picture, it is very close the break. Should I remove it?
Also, there seems to be a leak on the very right throttle body insulator. Should I replace the insulator?
I would only remove the CCT if it was in the way of the welder. It might be a good time to get a manual CCT if you were so inclined. It's a real bitch to get to it with the motor in the bike.
As far as the throttle body boot, you might want to look at that and see why it is leaking. Replace it or maybe it's not snugged up?
02 CBR 954
Removing the CCT is not really recommended but it should be okay as long as the engine has no likelyhood of being turned over while it's removed.
I would just crack the bolts and remove it once you have it in front of the welder and reinstall them as soon as the job is done.
You don't need to adjust the tensioner but you will need to wind it back in so you can install it and then release it to tension the chain.
While you have the engine out I would strongly recommend checking/adjusting the valve clearances as it's so much easier out of the bike, and you can confirm the cam timing is correct as well when reinstalling the tensioner.
It looks like the manifolds are not fully seated?
Have you checked the vacuum line to your FPR is not pulling fuel?
Is there a tutorial on checking/adjusting valve clearances? I've never messed with valves before. Thanks
Either the OEM or Haynes manual adequately explains the process.
Just read the manual and holy crap! I don't think im personally going to mess with the cam and valves. It will probably end up worse in the end.
Agreed. For someone the least mechanicaly inclined it´s in reality rather easy. Further as Bladeracer points out it might be a good idea to check camphasing anyways while at it-together with checking valve clearance.
On the topic of AC light alloy TIG welding then.
Being one of those that pull those kind of jobs like they were going out of style i can tell you that removing the CCT is not an option. It HAS to come out. As you weld aluminium the heat of the welding spreads VERY fast and as such i can guarantee that the CCT will experience WAY more heat than it ever was designed for seing the close proximity.
In recap, it HAS to come out. No two ways about it,and especialy so with the spring in there in mind. When spring steel is subjected to high temperatures it loses its characteristics-and fast.
Further it would be a good idea to use a diegrinder with an aluminium cutter AT the break to cut a 2-3mm deep and approx 45deg angled welding ditch. This will be filled by the welder anyways as he does what he´s supposed to and that brings a weld that won´t protrude all that much when done.
Make sure to cut that ditch like less than an hour before the welding and that will enhance the chances of a good weld plentyfold(aluminium starts to oxidize as soon as it is subjected to surrounding air and a "fresh" cut makes it less likely that you have to combat oxides as you lay down the weld which brings that the so called HF doesn´t have to be turned down as much as otherwise needed-which often makes for a better and stronger weld. If the TIG used is of newer variety with pulse and mix...disregard what i wrote above. Those TIGs can handle basicaly anything you throw at it in the right hands.
Well I wish you would have dropped the ball already and posted sooner, I already took the motor into the welder. Just kidding about the dropping of the ball :)
But when I took the motor in, the welder said it shouldnt be a problem, BUT now you have me worried so I called and left a message and hopefully he calls back before he starts working on it. Since I can't get to his shop because I work until 5 and that's when he closes(which is stupid), I was going to have him remove the tensioner. It's just the two 10mm or smaller bolts on the left and right side correct? Shouldnt be too hard of a task for him. What you guys think?
Ok, the tensioner was removed, but I did not set the motor to top dead center before removing it. Should I be worried now? Will the cam chain adjustment be out of wack now? I know it could possible jump and then a valve would be hitting the piston. Would a good way to tell be putting the tensioner back in the cylinder head, and then turning the crank by hand and listening/feeling for anything hitting inside of the engine?
There is a cam chain retainer that pretty much traps the cam chain on the cams, so jumping time is very unlikely.
Just don't rotate the cranks and you should be fine.
As far as putting the CCT back in, there is a cap on the end of the CCT that needs to be removed. Under that cap there is a slot like for a screwdriver. That is what you use to back off the CCT spring. It's a bit tricky because it requires you to hold that spring back while you install the CCT. Otherwise the CCT will be fully extended. You do NOT want it fully extended while you screw the CCT back onto the block. It takes a pretty small screw driver to back off the spring in the CCT.
You should do this yourself. Don't have the welder do it.
It´ll do.
The welder either used saltwater resistant weldrod or to high a HF(high frequency) when welding though.
All that black coloured goo in the weld is impuritys within the material,and when you bring the TIG to it the "dirt" within the aluminium will float to the surface of the welding core.
Aluminium is a fantastic material to weld as you get to understand what is needed. One reason being that you can basicaly reheat the material to hearts content without any profound ills come into effect.(Compare either black steel or stainless-that you touch ONCE with the TIG...or redo the entire structure/piece)
In short that brings that you can "build" witn aluminium too. In essence just like you´d use bondo.
FWIW..and FYI boys....when working with aluminium use COARSE tools. For instance,if you are to cut a piece of sheet lets say 1/4" thick...use a scroll saw with the same blade you´d use for wood. Just be sure to ad either industrial spirits or lubricating oil a´la ATF or similar as that will keep the blade clean(otherwise it´ll clog like crazy)
Likewise with a diegrinder. The coarser the cutting bit the better.
Welding of any alloy is best left to us that do it and do it more or less often. The welding of alloys...takes a bit to get the hang of to be good.
This is what a well executed alloy weld should look like. In this case a diffusor plenum for a high end turbo engine.
1 - 15 of 15 Posts
