1 - 13 of 13 Posts
Hey guys,
I am having a problem with my 2005 1000RR AKA Fireblade. Its like when i rev it it cant touch the red line doesnt matter if its neutral or in gear. i have checked the fuel pump pressure and its fine slightly more than 50 psi and i have installed new NGK spark plugs as well. The clutch plates are new but i didnt changes the pressure plates and the springs, as they seem to be OK. Another thing i d like to mention is that i also took a reading of the current going to the fuel pump and if i connect to the first positive (NEGATIVE IS COMMON) the current is 11.40 approx & when i connect to the second positive & turn on the key the current reading is 12.55 approx & comes back to zero after a sec or two...Total mileage on the bike is 25000 Kms... Please i need some help as its been a long time i havent riden my bike & now when i was about to, all the performance is lost... :((
Give the battery a good charge, check valve clearance and carbs
How long has it been stored? Did you use any fuel stabiliser?
You were advising him to clean his carbs ... he doesn't have any. ;)
What's the bike doing? Is it just running out of oomph or is it limiting? Have you tried disconnecting from battery, letting it sit for a bit, then reconnect and start over? Not sure how to reset a newer ECU but my ignorance says if you remove power it'll reset?
Aside from not hitting redline does it seem to have normal power or lacking?
hey guys....Thx a lot for ur kind suggestions & i have found the problem finally..The problem was with the fuel pump :D it was having the correct pressure but wasnt pumping out the right amount of fuel. I hope u guys understand what i mean.... As the quantity of the fuel was insufficient it couldnt produce enough power to touch the red line...i have changed the fuel pump motor & its fine now...I didnt wanted to spend on the whole new unit of the fuel pump so i installed HONDA CIVIC fuel pump motor..hahahaha & its working fine... LOL :) thx guys again...
Discussion Starter #13
ummm not really but yes as compared to the UK... the temp around 23 during the day tym n around 14 at the nyt tym.. :)
1 - 13 of 13 Posts
