1 - 1 of 1 Posts
SPECIFICATIONS
Model: CB300F
Engine
Engine Type: 286cc liquid-cooled single-cylinder four-stroke
Bore and Stroke: 76.0mm x 63.0mm
Compression ratio: 10.7:1
Valve Train: DOHC; four valves per cylinder
Induction: PGM-FI, 38mm throttle body
Ignition: Computer-controlled digital transistor with electronic advance
Transmission: Six-speed
Final Drive: O-ring-sealed chain
Suspension
Front: 37mm fork; 4.65 inches travel
Rear: Pro-Link® single shock with five-position spring preload adjustability; 4.07 inches travel
Brakes
Front: Twin-piston caliper with single 296mm disc
Rear: Single-caliper 220mm disc
Tires
Front: 110/70-17 radial
Rear: 140/70-17 radial
Dimensions
Wheelbase: 54.3 inches
Rake (Caster angle): 25° 30’
Trail: 98mm (3.9 inches)
Seat Height: 30.7 inches
Fuel Capacity: 3.4 gallons
Estimated Fuel Economy:** 71 MPG
Color: Red
Curb Weight*: 348 pounds
1 - 1 of 1 Posts
