Hello everyone.
I'm really new to the forum here, so hoping someone can help me.
I've just bought a neglected 600 F2 1994 model which has sat for some time. I've replaced battery and got it to crank over.
It leaked fuel everywhere, so I took off the fairings, stripped it down to the head gasket. Replaced with a new one. Reassembled everything, and now fuel p***es out of the drain holes (just below the each exhaust outlet on the outer side of the engine block). There are drain holes there, so I gather this would mean I have a sticking carb float.
I'm assuming this as it can empty half a tank of fuel onto the floor in less than 3 minutes. That's how fast the fuel is coming out. I didn't feel like risking fuel near a hot exhaust any longer so turned it off. The bike starts everytime though. I'm confident there's now no leak on head gasket (coolant not contaminated, no oil in water).
I've taken carbs off and tapped throttle bodies. They sound different, indicating a couple are stuck?
Please see here for video.
I've got them soaking in carb cleaner at the moment.
Anything else I should try while I've got them apart?
Also, I've supposedly got a vacuum line coming off of cylinder 1. This isn't connected to anything. Cylinder 2 has a closed off port. Cylinder 3 and 4 don't have any pipes/tubes coming off them. Where do I connect the vacuum hose?
My fuel petcock does not have a vacuum line. Possibly aftermarket? It's got one pipe coming off which just simply goes to a T-Piece for the carb feed.
I'm hoping that once the floats are cleaned and working the niagra-falls effect of fuel escaping will stop. Anyone else had this?
Many thanks for any info.
