Hi dudes!! :cool:
1. When I turn the key on the F4 and turn red button on and after press the starter button - I dont hear the fuel pump, but the starter turns as normal.
2. When I turn the key on and turn red button off and press the starter button - i hear fuel pump.
Thats means - fuel pump work good, but fuel pump dont start when i turn key on. What problem here? ECM?
So what did you end up findig out what was wrong? My bike has the same exact problem. The starter works just fine but it does not prime....I hooked up the fuel pump directly to the battery and it works.....and the starter turns over just fine....I would appriciate the help..
Thanks,
Kyle
Yeah I dont think it is my bank angle sensor because I unplugged it and I put a jumper across the two terminals. But on the other hand when I leave it plugged in it will blow a fuse..
