1 - 2 of 2 Posts
okay... bit of an on-going problem but here goes!
my 2000 cbr 600f x only starts when:
cold: easiest way is to bump - can hear the start motor and it sounds like it wants to start but it doesnt... once started from cold the bike will ONLY idle off the throttle... any amount of choke kills it.
hot: will work off the button
once warm the bike runs lovelyyyyy.
what I have done so far:
cleaned carbs
Cleaned SE valves
checked plugs (look okay but a bit old)
any other suggestions?
Cheers
Try cleaning carb jets. And check float. But on my bike I have no power, replaced starter selinod switch, ignition switch, and rectifier. My manual shows another fuse somewhere besides the main fuse and the fuses in the fuse box. Can somebody tell me where it's at? Thanks!
1 - 2 of 2 Posts
