Hi, I have a 1989 cbr600. I had it running in january perfectly. I garaged it for 2 weeks due to bad weather. I went out to start it, but the battery was flat. I charged it up and tried starting it. It turns over but does not fire. I have since got a brand new battery. I have tested the fuel relay, and found that it did not work, so its been replaced. I have also fitted a new fuel pump and changed the regulator, and coils. The engine turns but i have no spark!!!!!:mad:
can anyone please help me?
thanks in advance
thanks in advance
Bad kill switch perhaps.
Bladeracer: thanks for your reply. I have pulled the switch apart and cleaned it up. I seem to have got spark back, but i am not sure if it was the switch or if it was because I replaced the ignition pick up. Now its to get the fuel through the system.
Have you any tricks to get it through quickly, or is it just a case of being patient and keep cranking it?
Thanks in advance
