1 - 1 of 1 Posts
I have an engine case for a 929. Top and bottom. The bike was dropped on the left side cracking the stator cover and the forward mounting tab where a bolt holds the cover on. The actual flat area area where the gasket lays between the cover and the case and seals has not been cracked. The mounting tab has been professionally replaced by an experiences aluminum welder. The tab just needs to be drilled and tapped for a stock bolt to go back in. Let me know if anyone is interested.
513-266-7934
1 - 1 of 1 Posts
