Is is possible to install a 929 front wheel+rotors into a 954? I have vibrations when braking, and although I bought a brand new right disc last year I still have problems. They rebuilt my calipers but the left one is still stuck :(
I guess it is a direct swap right? Calipers too?
Thanks for your info, I just wanted to make sure
Yes I own both bikes, axle and spacers and calipers/disc fitment look identical although they may have different size pistons (I don't think they do) I have never actually swapped the wheels from one bike to another but I currently have 2004 cbr 1000 wheels on my 929 and they fit straight in too you just have to use 929/954 discs as they come with smaller ones I think 310mm rather than 330mm.
I made a video removing the 1000rr wheels if that helps at all... I go over the top with the rear chain adjusters just tried to show its' good practice to check they are free'd off...
Good luck!
Good luck!
Wow, interesting, thanks for all the info :)
I just checked it and I've got a bent rim, and both rotors too :(
So did you hit something, or did you buy the bike like that?:unsure:
I bought it with rotors in a really bad condition, but it was my 2nd bike (after a suzuki gs500) and I didn't notice it :( I'm installing new NG brake discs
About the rim, yeah, I hit a really big rock, it even lifted the front, quite scary actually because you don't expect it
