Hej everybody,
I got a cbr 929 2001 and the fuelpump doesn't prime/works.
When i put 12 volts direct on the pump it works.
On the fuel relay i got on the two black/white cables 12 and on the brown/black also.
On the brown/grey spotted kabel that's going to the fuel pump doesn't come any voltage.
If i change the relay of the fuel cute off with another doesn't help.
On the hiss cables yellow/red and the pink i got +/_ 5 volt when i measure on the main connection and the hiss antenna isn't plugged in.
When i start the bike and i put 12 volt on the fuelpump the bike runs like normal but stops running when i don't give it 12 volts.
All the ground that come together in the orange connection is fixed and so far i know all of them are okej.
Hopping that someone knows what is going on because i dont know anymore.
Check inside the right handlebar switch for broken or loose connections to the kill switch.
Discussion Starter · #3 ·
Thanks for the that. worth to check.
Byt just one question, how does that give me power to the pump.
On the fuel cut off relay i have 2 black/white with 12V and a brown/black with 12V when the ignition is on.
Byt nothing from the brown/grey that is going direct to the pump.
I did change the relay but that didn't help. what am i missing here.
“Most” of the time when a 929 won’t prime, but will run on direct 12vdc, it’s the ECU.
There are several threads on the subject throughout the forum.
The power goes through the pump housing via a brass block. My 954 lost contact there. I used a dremel and ground out all of the epoxy and soldered the connection solid again. Then I filled with a gasoline safe epoxy.
The brown/black is the low fuel level light
