Hello,
I have a 2001 CBR 929 RR that the ignition key was left on for 20 minutes w/o the bike running and now it won't start; gets fuel but no spark. I've replaced ECM and bank angle switch and checked the wire connections and fuses. Any idea what else could be causing this?
Are you positive it has no spark? How did you check the spark? I can't see any reason that leaving it on would cause an issue other than a dead battery..
Discussion Starter · #3 ·
Yes checked spark and none it's getting fuel replaced the ECM and bank angle switch still nothing and new battery
Try checking the HT coils, it is described pretty well in the haynes book. It could also be the connector to the coils, you can see it to right.
be of luck!
Hello,
Flat battery?
