1 - 1 of 1 Posts
Hi I'm having a starting issue sometimes it can take 15-25 tried to get it started of turning the ignition on and off as the fuel pump doesn't always prime but it the fuel pumps disconnected and tested the pump primes every time I've had a new key and transponder done to rule it out a new fuel pump relay tried a new ignition barrel and didn't change anything all wire coming from the ECU have the correct vaultage it's been put on a diagnostic and showed no faults while running only thing that's not been checked yet is the tilt sensor anyone have anymore ideas
1 - 1 of 1 Posts
