I had similar @idle+1/4_throttle issue along with a noticeable stumble that came on at 7-8k++RPM; there is one vacuum line attached to the FPR running towards the engine and it splits at a T-junction into 2 more lines that attach at the intake plenums of the #1 and #4 cylinders. I found liquid fuel in both vacuum lines which denotes a faulty diaphragm inside the FPR. I replaced the FPR and that resolved the idle/throttle issue. The high RPM stumble remained, so I inspected All Plugs+CoilCaps<All 4 plugs were in spec., Resistance for Coils in spec. but the #1 & #4 CoilCaps had oxidation/rust on the spring-retention clips inside of the boots that degraded them beyond their ability to spring back into place and retain a solid connection to the spark plugs. Taking the boots off is a bit of a tight spot, and this a good example of where dielectric grease was helpful in reassembly and can prevent the type of oxidation that obviously affected these parts. I replaced them with a set of used CoilCaps from a parts yard that were in much better condition and the high RPM stumble was resolved. Best of Luck~
