Currently have my 954 for sale. I am returning the bike to nearly stock trim and will be adding more parts as they are removed from the bike.
Lowered front seat $SOLD
Red OEM solo seat cowl $SOLD
XS Boost Manual fan control $30 fan works as normal when off or you can run fans all the time to keep motor cooler
Make offer if interested. Prices include shipping to lower 48 states. Payment by paypal
I'm interested in the seat. is it the stock foam shaved down or?
Let me know-Tim
Let me know-Tim
It has some of the stock foam with a thin layer of new foam over it. I bought it cut down from stock then modified the pan by narrowing it to match the subframe then had a new cover done by a local upholstery shop
Discussion Starter #4 (Edited)
EK 520 ZZZ Chain with 2 new rivet style master link $75 Shipped to lower 48 states
Its long enough for bike to be about 7" over OR easily shortened to fit stock wheelbase. This chain is one of the strongest tensile strength 520 chains ever made. If it can stand up to drag racing no way it will ever break when used on street
Got some parts from backdoc and everything was exactly as described. Pleasant transaction and would definitely buy from again.
Custom Hindle Full Exhaust Dyno map file for PC3 $100 (will be sent by email)
Dry Nitrous Spraybar $130 Removed from my 954 so guaranteed to fit. For $300 I will include 2.5lb bottle bracket that was welded to swingarm (must have extensions to have space if front of rear wheel), nitrous jet (~40HP jet that was drilled and used in my bike that matches PC map file) along with custom nitrous map for PC3. All you would need would be bottle, solenoid, nitrous line from bottle to solenoid, nitrous line from solenoid to shower head, shower head with 1/8npt to 1/8 poly line push fittings to have complete nitrous kit. Can provide install help if needed. With this setup bike went [email protected] 1/8 mile and [email protected] 1/4 mile
Stock clutch and front brake levers $30
Spiegler Front/Rear Brake Lines - Black with Black Fittings and Banjo bolts $80
CBR Mirror block offs $9
Complete 954 stock rear wheel with rotor and sprocket carrier and rubber dampers $125 (straight good condition but has some nicks around edges from tire changes)
Racetech Gold Valves in Front Forks $100 to trade. You will have to take apart your forks and remove the stock valves from the bottom of each damper or send me the entire damper. When I get your stock ones I will send you mine setup for 180lb rider along with remaining parts from the Gold Valve kit so you can change the setup
Make offer. Free shipping to lower 48 states
