Here is the beginning of my restoration of my 954. I picked it up as a basket case. Fuel tank is complete, sanded bare, 8 coats of red, wet sanded in between each coat. I painted the black stripes instead of using decals, 4 coats black, wet sand in between each coat, and then 4 coats of clear. I decided to paint the gas cap metallic bronze as I believe it enhances the bright red instead of the bare aluminum. The rear section is also complete now with all new bearing, and seals. The engine is broken down as I work through each and every part inspecting and replacing as needed. All in all, everything is coming together nicely.
