1 - 2 of 2 Posts
ive got a problem with my front brakes, they seem to pulsate (judder)when i put the brakes on. What should i check? or is it a case of replacing the discs which are not cheap are they. unless someone knows somewhere.
thanks to you all.
thanks to you all.
Most likely bent or warped discs.
If you've fitted a tyre recently they're probably bent and you can straighten them very easily.
If they're warped then you'd have to replace them if you find it too annoying.
1 - 2 of 2 Posts
