i just bought a 1996 cbr 600, i was rinding just up an down the street i went as fast as maybe 45 an i was going threw all the gears but for some reason it wont go into 6th, any ideas
You do know that first gear is down and there are only five up-shifts to reach sixth gear?
has no trouble going into 2nd, an yes i obviously know one is down
Then I would check the shift ratchet, drum and pawl - but you'd have to remove the clutch basket to do so. Have you asked whomever you bought it from if it has a transmission problem? Even better if you can find the shop he used to use for servicing at they should know if the bike has problems.
