Looking for suggestions on the following issue on my 2008 Honda CBR 1000:
The turn signal and high beam function work, however, the indications on the cluster are acting up.
With the RH turn signal set, both turn signal indicators and the high beam indicator blink on the cluster. The LH turn signal indicator works fine with no high beam indicator interference. Turning on the high beam lights up the high beam and both blinkers on the dash.
So far we could track the problem down to the cluster circuit board itself. The board looks clean and so do the solder joints. We resoldered some of the capacitors to make sure there are no cold solder joints but that did not solve the issue.
Anybody else ever had this problem? A circuit board diagram would help as well.
Have you opened up the Switch gear Hi/Lo and Indicator switch gear to clean them up , and are the front left and right Led's working OK?
As MrPickwick says switch gear maybe. Everything but turn signals worked okey for me on my 954. I cleaned twice but not better so ended up with changing the whole switch gear and now everything works perfect for me.
