1 - 2 of 2 Posts
Hi guys, i'm a new member and not sure if i've posted this in the right forum but does anyone know if a 1000rr motor will bolt into a 954, cheers, Mark....
Well that really depends on whether you know a good fabricator or not. Because the swing arm is actually supported by the motor on the 954, you would have to weld some type of material to the frame to attach the swing arm to if you wanted to upgrade to the 1000RR motor. the 1000rr attaches the swingarm to the frame. Can it be done? yes will it be a bolt in job? not by a long shot. hope this helps
1 - 2 of 2 Posts
