1 - 9 of 9 Posts
hi guys just bought a great 1997 600f but need help pls 1st 2 nd gear great then it more or less near stops it has an yoshimura system on it down pipes complete system pls help the bike has only done 20000 miles and the dick dealer has left me high and dry i am at a loss as i only ever had 2 stroke bikes ie my fav is my rgv250 so i need easy steps to fix no nothing of 4 strokes thank you peps
Some areas that can be the concern:
1) fuel starvation issue
2) carb issue
3) coil issue/spark issue
Best way we can help you is to give us a better description of what's going on when "near stop." When it near stop and you put it back in first/second will it have full power again. What rpm are you at during first and second. Does speed play a factor, if you skip third or fourth will fifth have power again?
thanks for fast reply seems great after cold start let it warm up and sitting idle will rev to the red on riding 1st gear lots of power 2nd gear seems ok then starts to hold back 3rd gear splutter power splutter power 4 th gear no need back to 3rd to keep going loss of power again back to 2nd power then dies again same on repeat
as i said race system on bike but surly this couldnt be the problem bike set for maybe a year new petrol was put in pl help not looking sympathy but need cheap fix as i spent all my cash on her
How many miles have you put on it since you picked it up? Did the previous owner install a jet kit with the exhaust upgrade? I would start with maybe pulling the air cleaner and spraying some carb/choke cleaner in there. Is there anyone living in the airbox or the filter is clogged? It doesn't take very long for things to get gummy in the fuel system. Maybe sticking floats or partially blocked jet ports? Try and download a manual and set all the carb settings back to the factory settings to start.
Just trying to sort some of the possible simple things first and maybe save some $$.
I'll even throw Ian under the bus, he'll be along shortly:rotfl:
Sorry for the delay Jdoni, but here I am:rotfl:
Sabotage listed good points to get a start on. Bikes that work good in 2 gears should work in all gears. Can you get the bike to "work through" the supposed dead spots? Can he bike be ridden at all in 4th 5th 6th? So far it seems carb related. Have the carbs come out to be checked and cleaned? Do you know what size jets you have and where the needle is positioned? If the bike has sat unused for more than 12 months consecutive you can bet the carbs need a thorough cleaning.
You listed in your title is a 1997 CBR600F. Is that an F3, or a European variation of such? And F3 will have all sorts of ram air plumbing, etc that can drive you nuts if it's been "tampered with".
Aside with all that, the fees you're piling up here may go away if you post some pics of her:eyebrows:
hi guys just in reply to the help you offered it turns out it has a problem with the ecu so getting sortrd as i type thanks for the help
ok guys it was not the ecu it was the balancer nipples lol the dick that set the bike up forgot to replace the covers so the bike was just sucking loads of air on the down side 2 valves have been damaged but at least the problem was found hope this thread helps others
1 - 9 of 9 Posts
