Hi everyone, first post looking for some help!
I've recently got my bike back after having it's winter service done - oil filter and oil change, new sparks etc; then I got a new alarm/immobiliser fitted and for some strange reason the bike is running like hell:idunno:
Everything was fine before the service, and even to a certain extent after it was done it was okay (except for the neutral light staying on - which has now been fixed).
Then a few days later it got the alarm/immobiliser fitted and after getting it back the bike has lost all it's power.
When you put it into 1st gear it takes off as if it's in a higher gear, acceleration is low, and the bike itself even sounds different:confused:
Anyone got any ideas as to what the problem might be, or where to start looking for a problem as I'm lost:crying:
They screwwed something up from what you say. I wouldnt be lookin on the board for fix its. Id take it right back to them and dont let up on them. Just from the bike leaving the place and the neutral light being on even while in gear, that would tell me that they prolly didnt test the bike when they were done with their work. Sounds like they want money for no quality.
Thanks for your reply.
The neutral light was on (intermittingly) after leaving from getting the bike serviced, however I took it back and they checked it and it turned out to be a duff connection and that was fixed.
The alarm was installed at a different place and obviously somewhere between both events taking place the problem with the power started.
On leaving the garage last night when I picked up the bike after the alarm was fitted, I noticed the loss of power but I did'nt think too much about it as the bike had been there for a week and I thought that maybe the battery had drained a bit (or something to that effect), but after being on charge all night the problem is still there.
I just don't understand what could cause this out of the blue after everything was fine with the bike, I doubt that it's the alarm as I can't see what problem that could cause (and I can't contact the place until Tues until they're open again), so that's why I was hoping for some guidance on here as to what might have happened.
Any suggestions gratefully received:hmm: I'm stumped!
