1 - 20 of 69 Posts
Very cool I have a VFR swing arm and hub at home how much machining did it take?? From what I have at home seems like a big job. How many hours did it take? Was it overly difficult on a scale of 1-10?
First off, what year is your swingarm? No, it was not really that bad, I have everything lined up perfectly. had to make a new pivot bolt, bushings, and shock linkage. If you have the right year model VFR swinger, 98-04, let me know, and I can guide you in the right direction.
Tom
Don't think it's complete.....I dare say it wouldn't ride too far without a chain!!! LOL
Looks good. I can't say I'm a streetfighter fan at all, but I'm impressed by what you accomplished.
Enjoy riding it!
Thanks Sime, I have put alot of time and effort into making this right, and look good. And no it will not ride well at all without the chain. LOL
Tom
Are they much different than a '96 cause that's what I have?
I love single sided swingarms, until you get to the hub side and I'm like, let me go back to the otherside.......yeah.... that's nice.
spookyjack, you will need a 98-04, it is the same setup as your 929. If you happen upon one, let me know, and I will give you the info you need to get it done.
Hondapowered, do you go to Quacker Steak on wednesdays? I will be there in the next couple of weeks, I have to finish polishing, and a few odds and ends to tie up.
Tom
Looks pretty damn good ! How wide is your tire, can you go wider? I'm also planning on doing this conversion but have to get a swingarm 1st. I will for sure look you up when i get ready.
Also what did you do for your front tire? What parts did you have to have machined and what about weight and handling? Thanks. keep it btween the ditches!
Discussion Starter #14 (Edited)
Well, for the front tire I have not done anything yet, but I am looking at a RC51 front wheel, it is a 5 spoke. I had to have the swingarm machined, and I had to grind off a notch on the inside of the VFR swinger, so it would let the arm far enough forward to let the pivot bolt through. I had to make a pivot bolt that was the same size on the end as the old pivot bolt so that the pinch bolts will work on the swingarm carrier, then I had to make a sleeve that would go into the engine to space the new pivot bolt, and a spacer made to take up the space on the shifter side of the engine. Last but not least I had to make the swinger linkage. In the pics above, it was the first time I had it rolling, I sat on it, and the bike feels just like it did before the conversion. As for weight, it did add some pounds, maybe 10 or so. I cannot speak as to handling, I have not had it on the road yet, but I will let you know when I do, it should be in the next couple of weeks. When you get closer, I can give you more details.
Tom
AHHHHH!!! you're killin me...i've been dying to do this mod to my 929 for years...just lost an auction on ebay too for a vfr setup....looks great, really great...hopefully this season i can make it happen...enjoy!
Discussion Starter #19
1 - 20 of 69 Posts
