1 - 14 of 14 Posts
as they say, have you got the right lever, as you might know the 954 is not the same as the 929 so if you have the wrong one it might be the cause. The lever i bought for mine needed some alterations to make it fit right.
Discussion Starter · #7 ·
It is an OEM lever for an 02 954. I just pulled the pin on the old one and replaced it. Now, when squeezed it does not return to the position before being squeezed and the brake is on when I let go of the lever.
1 - 14 of 14 Posts
