In long config, we have two straights...The longer of the two is just over 1/4 mile and I see 142-145 mph on the gauges before braking on the 929...the R6 has speedo covered so no idea.
The next order of business for mods is going to be aftermarket clipons (must be at least as high as stock or adjustable as comfort is important on this bike), braking, and fork internals to match the Ohlins shock out back.
As I said, the main reason I was looking for info on 954 throttle bodies isn't for power gains, but for the ability to interface with a tuning box that has traction control and quickshifter built in. Bazzazz doesn't make one with 929 style connectors, but they do with 954 ones. I would like to get the whole Bazaazz setup...fuel, igntion, quickshift, and traction control.
I wonder if it would be possible to tune the fuel for economy better than than stock at part throttle settings, like infield, and on short track config where the bigger bikes are never able to stretch their legs, and then map it for power above 80% throttle opening or something like that? I am certainly no good at tuning or any of that...I just ride the damn thing,lol.
As for fuelling during an endurance race, the officials come and watch every team's pitstop.
If you are using lawnmower style gascans, the bike must also have a ground strap to steel on the ground, like a pair of booster cables or something, and the bike must be on a stand, motor off, rider off. If the team has a dry break quick fill setup, no stand or ground strap is needed, but again, motor off, rider off. Any variances from this is immediate DQ.
As far as throttle body replacement, I asked the series owner, and he just laughed...said do whatever you want to the bike, so long as stock frame, engine block, swingarm, and fork tubes are used. No nitrous or turbo,LOL.
