Hey guys, bought an 02 CBR954 back at the end of September with a rod knock. Always wanted one of these and have never done a full rebuild on a motorcycle. I have a good back ground in building drag cars so with good tools and a Haynes manual I dove into it.
This is the bike when I got it home, not perfect, but I was in love.
This was the next day of course, couldn’t resist even though I had to be at a dinner at 5pm.
Pulled the head off to inspect the bores, they didn’t look bad from the top of the pistons up. But…
The bottom of the cylinders were bad, could catch my finger nail on a lot of scoring so I had a choice to make there.
My work bench with the entire motor torn down next to my race car 87 T Type with twin 71/75 precision turbos, 427 LSX
My first was born a week after getting the bike, my wife is a badass and let me build the motor in the den. Ended up doing a .25mm overbore with the Honda oversize pistons and rings, the crank and a rod were torn up so I got a used set of rods and crank on eBay so I could pick and choose. Full set of gaskets, O-rings, new oil pump, new timing chain, chain tensioner, fuel pressure regulator. All new Honda parts there from partzilla. Basically a complete stock rebuild. Found a couple worn out dog teeth transmission gears so I replaced those as well. All in all I spent way more than expected with the need for pistons and a bore, those pistons are not cheap! Picked the bike up for $1500, spent $3k on everything. So $4500 in total. Yes, I could’ve bought someone’s clapped out junk for this price or less. Yes, I could have bought a complete, “good running” motor on eBay for $2200 shipped to my door. I didn’t do that after reading about 2nd gear issues and cylinder scoring issues, I wanted to know everything was done right.
Cylinder heads had a lot of carbon build up, cleaned up up and assembled them on the bench to check valve clearances which were all in spec.
Motor going together in the den. Piston rings were all in spec out of the box, not sure if there was something goofy there with the bore, but I put it together and seemed good. I’ll continue in the next post since I’m only allowed 10 attachments.
