1 - 11 of 11 Posts
I'm going to adjust and lube the chain on my rc soon. The manual says use 90wt. gear oil, but I see most people on youtube use spray chain wax. Which is better? Wouldn't oil collect more dirt?
only just started using wax last six months and i recon it is better, not as much spray over wheel. But noticed you will need to clean out front sprocket cover now and then as it builds up a bit.
Chain wax is all I use and it's great. Like RICK says, you do have to clean up the build up once in a while with WD-40 so the sprockets and chain are nice and clean, then start over. Maybe two or three times a season for me.
Can't even imagine using 90 weight gear oil. What a mess!
"rccarver", I use Chain Wax. Had five different bikes, startted using Chain Wax back in 1988. Yes, you do have to clean out the front sprocket cover, every so often. I use WD40 to clean up the excess, and keep the chain clean. When ever I get back home from a ride; I usually spray Chain Wax on when the bike is still hot. You can see this stuff whick on to the chain, when the chain/sprokets still have some heat in them. Its the best chain lube out there. Plain old oil is last ditch effort for todays chain and sprocket.
I think every type of lube on the market, picks up some amount of dirt/gritt.
Thats why its called chain maintenance. You gotta pay attention to your chain;(I'm sure you realize this.:cool: ). Clean it like Denzee does. Chains are pretty tuff, they can take a little dirt. Just don't neglect it and use Chain Wax.:thumb:
I have been painfully applying 80-90 wt gear oil to my chain. It still looks like it's rusting on the outside. Where and from what manufacturer do I get wax chain lube? And can you use it on your stock chain?
Maxima chain wax is what I use and you can find it at most bike shops. Yes you can use it on your stock chain but you should remove the rust or replace your chain first.
I've heard bad things about WD-40 on a chain. Since it is a penetrant and not a lubricant they say it can work its way past the O-rings and dissolve the grease inside. I know people have been using it to clean the chain and not as a lube but I don't want to clean the sealed grease on the inside.
I use Simple Green on my bicycle chain to clean it. I might try that on my CBR. I bought some Bel-Ray chain lube that I'm going to try. Bike only has 300 miles thus far.
it will lats at least a week depending on how often you ride...i also use maxima chain wax....get the big can...its worth it..ive heard guys also use a little kerosene on a rag to clean their chains also...i just use wd40...but im surious if anyone else used kero? The wax will work on any chain, oem or aftermarket...xring oring t ring....its all good! :)
I use kerosene to clean chain, its bit messy though, but does a good job removing old gunk, i also use wd40 as some of the other guys do, just to clean the outer chain links, then use Wurth high performance chain wax to lube, its excellent stuff..
1 - 11 of 11 Posts
