1 - 15 of 15 Posts
Hi guys
I found that my battery was not lasting on my bike.
It kept going flat after 2 months.
I checked the charge rate and found that it was charging at 15,6v with the main beams on and revs at 5000rpm.
Has anyone had this problem or know how to fix it?
Thanks guys
Hi guys
Thanks guys
How much mileage does "two months" equate to?
Between 1000km and 1500km
Okay, so you ride it at least once every week?
I'm assuming the battery is flat when you want to ride rather than going flat while you're riding?
Is it a good quality battery or Chinese-made?
Have you tried disconnecting the battery terminals between rides to see if it still goes flat?
I ride about 2 / 3 times a week, and the battery is going flat between rides and the last time it went flat was during a ride. the battery was so flat I couldn't even run start it. And yes, it was a top-line Chinese battery.
You can't bump start fuel injection unless you have enough power to run the fuel pump.
It went flat during a ride despite showing a 15.6V charge rate?
What voltage does the battery have with the engine off?
When you turn the ignition on?
And how low does it fall when you press the starter button?
I'm not sure what the voltage is while riding ?
I fitted a new battery in today, and the volts showed 13.2v while the bike was off.
Only after fitting the new battery I tested the charge rate. On normal idling, it shows 14.3v, then tested with main beams on at 5000rpm and that showed 15.6v.
Surely during riding voltage can't climb to 15v?
And when I removed the old battery it smelled like a rotten egg (over sulphated)
15.5V is the specified charge rate.
I was asking about the measurements of the old battery to determine if it was the battery that failed.
Did you replace it with a Yuasa this time?
I can't smell so I can't comment on that part of it.
I did not check the charge rate of the old battery, due to the fact that the bike cut out on me while i was riding on the freeway about 30kms away from home aka Fuel pump failure ...just so you know, I am struggling with the fuel pump as well.
So i just went and bought a new battery today, its a Deltec battery, is it any good?
And any advice on repairing the fuel pump myself? Honda dealers charges a fortune for a new pump.
Sorry for all the questions, really appreciate the advice and help
If the battery is low then the pump won't run and the engine will stop running.
Never heard of Deltec but as long as it wasn't cheap it should be good.
Down here the Yuasa is around $165 last time I bought one, and worth every dollar compared to the sub-$100 crap.
No idea without knowing what's wrong with it.
Maybe it just needs cleaning or a new filter?
Since you didn't know the charge rate I'm guessing you don't have a manual, I would suggest you get one before throwing money at the bike.
Well here in S.A deltec is a good battery so i hope it works.
Yes it is a dirty fuel filter causing the problem, but in order to get a new filter you have to buy a whole new pump.The fuel filter is part of the fuel pump and does not seem to be serviceable.
So i have modified my fuel pump just to get the bike going again at full speed, but my modification only lasts for a while, due to the fact that the fuel line im using only lasts for a while, due to the fuel softning the line and it breaking cause of the high pressure of the pump.
Can you remove the filter to clean it though?
Is this hose you're using inside the tank?
If you can bypass the filter you can probably use a filter from some other injected bike, 929/954, F4i, GSXR's, etc.
Discussion Starter #13
The filter is inside a little black box, witch cannot be opened, so basically you cannot clean the filter.
So i have removed this black box with the filter inside it, off from the fuel pump. I then used 8mm rubber fuel line hose to complete the flow of the pump through to the injectors. I fitted my own fuel filter to the line and fuel pressure regulator.
Note this is all inside the tank.
The pump works perfect and the bike can still go to its top speed, the only problem is that the fuel softens the rubber, then the rubber line swells up and pops under the pressure.
It's not the fuel that's the problem, the hose needs to withstand 50psi minimum which is way above its design limit. Use high-pressure fuel line.
1 - 15 of 15 Posts
