1 - 2 of 2 Posts
Hi can the choke plungers on my 99 blade be lubricated for some reason they are not wanting to move smoothly and are bending the mechanism when I pull the choke out,it's been getting worse over the last few weeks
Try just blasting some silicon spray or WD40 (any seals on carbs must be oil/fuel resistant rubber, right?) around the plunger seals where they enter the carbs. If that's not enough, tank off, airbox off, and get in there clean up re lube and do it right.
1 - 2 of 2 Posts
