1 - 2 of 2 Posts
I have searched the knowledge base and also searched the forums and it seems no one has posted 'how' to tighten or loosen a clutch cable.
Is this because it is so simple?
I dont have much of an idea and would appreciate any info.
Thanks
At the clutch lever you'll see a knurled nut, it should be tight against the area opposite the lever, as it keeps the clutch cable tight. Loosen it and then you can turn the other smaller metal nut to tighten or loosen the cable. Then tighten the locking nut back up. The freeplay should be 10-20 mm.
1 - 2 of 2 Posts
