This is the clutch cable adjuster on my 06 f4i, see the attached photo..
My clutch handle was feeling pretty loose, so I tried to tighten it up using the adjuster. I don't feel safe having the bolt this far out, it's basically as far out as it can go and still be tight. If I tighten the bolt against the handle, the cable sheathing does not seat in the bolt and the handle flops around. What could be the issue? Is the cable stretched and does it need replacing? Is there an adjuster on the other end? Am I just retarded and don't know how to use the adjuster properly? Any help appreciated.
