1 - 20 of 22 Posts
the bike is an 04 cbr 1000rr lots of parts full micron exhaust pc3 ect 12866 on clock
contact by pm or [email protected]
the owner hit a deer first then got it back mechanically running. rode it for about 3 months and with a loose chain tried to race someone that passed him.
whala broken extension and some problem in the transmission. opened the basket to see if it was a broken rivit it was not.. so now for sale
bmc filter--------$65
front seat----$50
rear seat----$50
tank cover.......some rash----$20
left side.........some rash----$50
right side........some rash----$50
rear brake system......caliper master cylinder ect.----$75
tail light-----$25
gages....12866 miles on the clock much lower due to -2+5 gearing has small hole in cover---$35
headlight harness---$15
tipover sensor----$50
coolant tank........less 3 monts old oem---$20
radiator assy...........had a small leak owner jb welded the neck.----$100
micron full exhaust....small dings on mid-pipe' tire rubbed bottom of can----$800
tank with pump----$100
pc3 with micron map---$200
subframe with batt tray----$100
cdi......clips damaged-----$50
air box---$25
throttle tube with new oem cables---$55
upper stay.....may be bent slightly---$30
oem sterring dampner-----$50
drag race fork strap---------$10
rectifier/regulator.......i have 2--------$40 each
front brake system......calipers master lever ect-----$100
right clip on with on off switch-----$30
left clip on with light switch clutch master cyl everything----$75
lock set with key---$150
lower tree with stem---$25
forks......straight no leaks---$200
530 chain and sprockets........6 in stretch 46 t vortex 16 t front----$
rear shock assy-----$65
main wire harness.......clip at cdi busted still works------$70
swingarm----------$75
engine......something wrong in transmission, may be an easy fix not sure, otherwise a great running motor. racers if you need another motor have the tranny undercut and fixed up !!!--------$400
frame to be sold when payoff is reached and title is in hand. offers are welcome
owner may sell with bill of sale. vin is in the pics for verification.
_________________
click the picture for a slideshow
all parts are located in dothan al and are best offer
Discussion Starter #8 (Edited)
updated list with new prices new link for pics
cbr 1000 pictures by skip954rr - Photobucket
the bike is an 04 cbr 1000rr lots of parts slipon micron exhaust pc3 ect 12866 on clock
contact by pm or pat_wurst(a)yahoo.com
micron slip-on exhaust....small dings on mid-pipe' tire rubbed bottom of can----$300
front seat----$50
rear seat----$50
tail light-----$15
gages....12866 miles on the clock much lower due to -2+5 gearing has small hole in cover---$25
tipover sensor----$35
coolant tank........less 3 monts old oem---$10
air box---$25
throttle tube with new oem cables---$35
530 chain ........for 6 in stretch ----$make offer
_________________
I'm interest in the lock set and key and the wire loom. What all is included in the lock set and does it include the fuel lid? also what exactly is busted on the wire loom clip at the cdi? is it the clip that swings down to lock the plug in place? or is it the female plug itself that's busted?
Thanks
Discussion Starter #14
updated list
micron slipon exhaust......small dings on mid-pipe' tire rubbed bottom of can----$300
tank cover.........some rash----$20
left side...........some rash----$50
right side..........some rash----$50
gages......12866 miles on the clock much lower due to -2+5 gearing has small hole in cover---$35
air box---$25
front brake calipers -----$50
forks........straight no leaks---$200
engine........something wrong in transmission, may be an easy fix not sure, otherwise a great running motor. racers if you need another motor have the tranny undercut and fixed up !!!--------$400
Discussion Starter #19
updated list
air box---$25
on off switch-----$10
light switch ---$10
clutch master cyl ----$50
1 - 20 of 22 Posts
