There are two drain bolts.  Both are on the left side as you sit on the bike.
The first is the bottom right bolt on the water pump.  It should be the only bolt with a washer on it.
The second is bolt right above the overflow bottle, in the cylinder head.
Remember to remove the radiator cap or the cooling sytem will not drain.
Good luck,
Rick
K9inAZ : Remember to remove the radiator cap or the cooling sytem will not drain.
Thanks! Forget the radiator cap? I would never do something stupid like that...
doh! Radiator cap? Why didn't someone tell me!!
Well I fluked that one though.
Hate being mechanically uninclined.
