just wondering how long is too long to run the bike on just water, I know the racers use water only, are you supposed to put coolant when it's just sitting there between races? I've been running mine for about a week on just water as I cant face pulling the bike half to bits again to just add coolant and it's due for a service in a couple of weeks.
Is 3 weeks of coolant free operation going to cause issues?
You need to have at lease Watter Wetter in there for corrosion protection and to lube the water pump seals. Just suck some water out of the radiator and pour some in.
I thought the whole idea of race bikes running water only was to make it not really slippery if the coolant spilt on the track? doesn't water wetter have the slippery effect? I've never used it before so I don't know.
I think I'll just chuck a full load of coolant in- if I've taken the fairing off enough to get to the radiator cap the jobs almost done- just pull the water pump hose and leak a bit out
Water wetter is not Glycol based like most coolants therefore it's not slippery. That's why the tracks require it. You only need a few ounces of the Water wetter in there.
As far as I know, if your bike isn't subjected to freezing temps. you can run it as long as you want. I'd change it every other year like you would the antifreeze.
CBRVFR : I'm under the impression that you can run distilled water and Water Wetter indefinitely--- until it freezes. Perhaps not a problem down under??
Yeah, I'll probably put antifreeze back in mine by Oct. What's the reason for changing water/water-wetter solution every 3 months? I've had it my bike since May so I guess it should be changed?
never2old : Quote (CBRVFR @ Aug. 19 2003, 1:13am)I'm under the impression that you can run distilled water and Water Wetter indefinitely--- until it freezes. Perhaps not a problem down under??
According to Dan Kyle you need to change water/water wetter every 3 months. Actually he recommends coolant if you are not on the track.
I'd say this is very wise info.
I lost the water pump seal on my 929, and only changed the distilled water/water wetter once a year, when I'd drain out the winter coolant.
If you must run water, make sure it is distilled, otherwise the mineral deposits will foul the rad and pump.
Anybody want to talk about engine ice (the product, not the cracked block thing). Engine Ice is track safe, won't freeze, needs to be changed once a year. Also, I have done a lot of trial and error with my 03 rc51. Temps with engine ice are cooler than distilled and water wetter. The rc51 is a heat factory and I run no fans so I know what it is to watch a temp guage like a test scientist. I tried several products to keep my bike cool and Engine Ice was the best.
bigkid : Anybody want to talk about engine ice (the product, not the cracked block thing). Engine Ice is track safe, won't freeze, needs to be changed once a year. Also, I have done a lot of trial and error with my 03 rc51. Temps with engine ice are cooler than distilled and water wetter. The rc51 is a heat factory and I run no fans so I know what it is to watch a temp guage like a test scientist. I tried several products to keep my bike cool and Engine Ice was the best.
Actually I don't think it's approved for use at many tracks. Their ad says it's AMA approved but that doesn't mean it's okay to run on the track. There's another thread on this somewhere...
???? Better tell 50 percent of the racers out at MAM and lots around the country. ICE and WETTER is all we use around here. Of the local racers, I watch them pass tech all the time with engine ice at tracks around the country. Engine ice has no slippery glycol. And the best thing is you won't have to worry about freezing. I know two racers that hit a freak snow storm coming back from Kansas. Broke blocks inside of an hour.
Related Threads
1.2M posts
83.2K members
Since 2003
A forum community dedicated to Honda Fireblade motorcycle owners and enthusiasts. Come join the discussion about performance, racing, modifications, classifieds, troubleshooting, maintenance, and more! Find conversations about your favorite CBR 900 or 1000 series RR models.
