My indicators have stopped working on my 1997 CBR 900RR.:huh:
Indicators are fine, globes are good, new relay!:idunno:
Just wondering if a new Regulator Rectifier could fix this problem?:hmm:
Thanks
Richo
Thanks
Richo
Have you checked that it's charging okay?
If it's all the indicators maybe there's a break in the circuit to the switch cluster, the flasher or relay. Are you getting power at the switch?
I would check the indicator switch first, it may be corroded, if it is use contact cleaner, if its not that check the earth...
