1 - 10 of 10 Posts
Finally took some photos of the damage created when I lowsided my 929 a couple of weeks back. One can see the hairline fracture on the crankcase bearing support and to the dowel support. I have had the bike into my mechanic and supposedly it can be repaired. The motor will have to be pulled and stripped down then sent off to a machinist/welder specializing in aluminum repairs. Figured I would post the photos for some opinions.
Sorry to hear about the damage FreshTracks. That doesn't look to me like normal lowside damage. The heads of the other bolts on the cover aren't even grinded. Plus the way the dowel is bent back looks like it may have hit something. Was there anything unusual about the way your bike went down?
First I thought the repair may be able to be done on the bike but the cracks may be troublesome to repair. I would take it to a welding shop that does aluminum repairs before you disassemble everything. It's always easier for someone to say take it all apart because it doesn't affect them. If it ends up having to be disassembled, maybe you're better off finding other cases at that point or a used engine. Good Luck!
No, the crash was fairly typical (though it was the first one that I have done). The bike slid out on the rear first and basically it slid itself into the curbside median apx. 20ft away. The tires contacted the curb but it is possible that they (the tires) rode up onto the curb and the next thing to contact was the crankcase. This would account for the dowel being bent backwards. Best reflective reasoning I have.
I had the bike past the speciality welding shop that I will be using and it was their opinion that it was a relatively easy job to do as a repair once the engine was taken down. I have been looking for a new case/gently used engine but no luck anywhere. Honda wants alot of $$$ for a new case + the $$$ to tear down and rebuild by the mechanic.
i had mine weld right in the bike just removed anything in the area that might burn. go see the pros at a fabricating shop that specializes in aluminum
On a related note, what alloy is a 929 sump and crankcase? I have some 4047 rods to weld my subframe mountings and was wondering if I could use them on the fairing mounting on my sump which has snapped off.
I would've guessed it'd just be 6060 or whatever version of it they use for casting.
1 - 10 of 10 Posts
