1 - 15 of 15 Posts
OK guys lets face it if you ride on the track the chances are you are going to low side the bike a few times, if you are lucky you will not high side it.
I have noticed that the Honda’s and Suzuki’s do alright in the past, but I have been told that this year there are a lot of New R6's being totalled in relatively minor accidents on the street, I have not seen any on the track so I can not speak for that.
So I guess what I am trying to say is I think that Yamaha's new technology that allows them to make frames 30% thinner and stiffer, may help the weight but is not good for those that crash it.
What do you all think about this, with the new power to weight race that is going on, are we shooting are selves in the foot for power to weight ratios we will never use?
If I was between the 600rr and the r6 I would pick the 600rr because in can go down and still be repairable as for the 1000rr and the R1 I have always been a Honda then Suzuki fan whether it right or wrong that is another opinion.
The new lighter bikes, including the 929/954 do not crash well for the reasons you mentioned. They are very light and it seems that things just bend very easily. In the case of the 929/954, the cover grinds off easily, dumping oil all over the place.
I too have read of R6s falling off of race stands and having them measured by GMD or someone and they be off their previous measurements...  Really tweakable frames!  So what happens when you actually CRASH [email protected]!?
I can't speak for 929/954s but I do know of several RC51s that have been crashed REPEATEDLY and there has been ZERO variance in the measurements made after really sizeable crashes (not just lowsides).  Given that the 1000RR may end up being heavier, it could be just as strong...
Say all you want about heavy bikes (RC51, et al), there are benefits and a strong frame really is one of them...
The lighter, faster bikes we wanted are here, but along with them comes increased fragility, a by product of having less material doing more work.
I thought the idea was not to crash?
(j/k)
Seeing some pics of 'totalled' bikes by insurance company's standards, I don't think there will be much change as to the newer models.  I was amazed at what appeared to be minor damages translated into totalled condition. <shrug>
Edit: looks like you're not talking about insured bikes, rather track bikes. I'll go back to sleep now.
Well, I haven't had my bike measured since my crashes, but I have sent it through a low side (off track where it flipped from one side to the other sliding through the grass) and a high side (hit hard enough to roll up onto its top and come back down on the same side). I have visually inspected things and other than my subframe being tweaked and some grinding that occured on the swingarm it seems just fine. It is possible that things are tweaked a little bit but I sure can't tell it.
My biggest complaint with the 929 so far is the fact that if it goes down on the left side then you can pretty much count on cracking the stator cover and dropping oil all over the place. The good news is a replacement cover and gasket is only $60.
lfg929 : My biggest complaint with the 929 so far is the fact that if it goes down on the left side then you can pretty much count on cracking the stator cover and dropping oil all over the place. The good news is a replacement cover and gasket is only $60.
That's little consolation for the guy behind you running through your oil though. Not a good thing!
('you' as a generalization of course, not aimed at lfg)
I recently high sided my 929 and was relatively excited how well it held up. The bike barrel rolled twice and then went end over end twice....the result was a dented tank, smashed tail plastic and tweaked subfrmame (still useable), exhaust of course took a hit, and a couple other little itmes like a windscreen...total damage maybe 7 bills. As far as the stator covers go, I have exhausted this subject....basically two people make them-Factory and LP. Woodcraft should have one this winter as they are now done with the mold.
Purpdust : How amny of you put NKG (I think that is the Brand) covers on you bike befor you track it?
I know this time I am goint to get glass fairings nad covers before I go out.
I do not replace the stator cover. I know other people who have and have cracked the case when they went down. I have no idea if the stronger stator cover transferred more of the blow to the case, thus it being a major contributor to the crack, or if the crash itself was such that the case would have cracked regardless of what type of cover was on there. What I do know is that I will buy $60 OEM covers from now until the end of time just to not find out...
As for the oil...if the flaggers are doing their job then the oil flag should be out pretty quickly to warn people. If they are so close that the flag doesn't help then they probably would have gotten tangled up in the crash anyway. Yes, it is little consolation to the person who does go down in the oil and it does suck.
On a brighter note, one of the things I noticed about the new CBR1000R is that the stator cover looks to be in a much better position now to avoid damage from a crash. In fact, the motor in general seems to be fairly well protected and should hopefully result in far fewer oil patches being layed down due to a crash.
I recently tossed my 929 nose-first into a tire wall and came out with a shattered windscreen and some rashed lowers. I'm quite happy with the crashability factor...Well, as happy as one can be, that is.
HondaGalToo : The new lighter bikes, including the 929/954 do not crash well for  the reasons you mentioned.  They are very light and it seems that things just bend very easily.  In the case of the 929/954, the cover grinds off easily, dumping oil all over the place.
I can vouch for that...
Z...
1 - 15 of 15 Posts
