I'm changing the prestone on my 929, where exactly is the cylinder drain bolt??? I have a copy of the service manual, but I can't see on the picture.
Thanks!
Discussion Starter #2
Used the message search feature, and found the answer...... should had done that first
Glad you found your solution jetbdude, 'cause I sure didn't have the answer. And by using the search function you have probably made billions of friends!
